Sony's Prototype 360° 3D Display on Video
2 things..
1. it's way too small.
2. couldn't they have shown something more meaningful than just photographs? Like maybe a game or television show?
I'll stick with planar 3D monitors in a dark box for 3D effects.
seems cool.. but if its from sony it will be 10x more expensive than its worth
Guys, this was just a prototype, not intended for mass manufacturing. It's just a demonstration of a really cool idea. I could see this technology becoming really useful after another few iterations.
I can see the day when my computer will be talking to me through an avatar... A hot chick avatar!
Why do they only pan around the thing once for like 3 seconds? They don't really show off the whole 3d effect very well in this video :(
Yeah alot of still shots lol. Its 3d and your not even going to show it off?
You guys do realize your monitor is 2D right? So, it's kinda hard to demonstrate 3D. :D
If you have 2 monitors and a dual-head graphics card, your 2D monitor can be made to be 3D.
It's pretty simple:
1. get a cardboard box big enough to hold 2 monitors against adjacent sides.
2. make the inside of the box black using however method - black construction papers, black cloth, black marker, whatever. This is just to make the box as dark as possible so no outside light interferes with the display. Lay the box on its side so the opening is facing you.
3. install the monitors so that there's one monitor at the top, and one monitor to the back of the box. So it's 90 degrees of each other like this:
Code:
___________
then put in a sheet of teleprompter quality glass or Plexiglas so that it's 45 degrees between both monitors. (slanted lines in diagram above)
If you're running nVidia drivers, change the setting so that both monitors are running in stereoscopic mode.
Then sit back a bit and enjoy your 3D display.
It's been a long time since I read about this DIY 3D display, so I might be a little off.
Is this not just a 2D screen wrapped around into a cylinder? From there it's nothing but projective geometry to determine what to show on each pixel.
Meh, I can't really see any practical application for it, so that kinda renders it as a meh idea.
