Sony X720E Standby Mode
HA5
I read that the Sony X720E standby mode doesn't kick in for 15 minutes after the input signal turns off. Is that true? If so, that seem too long to be practical.
Anyone that uses this as a monitor, do you use the standby mode, or do you turn it on/off manually?
If manually, do you find the button on the tv or the remote easier to use?
Thanks.
