Future owners,
I thought I'd share my experience with you before you decide to purchase this LCD. This is not a review.
I just purchased this LCD on 2-15-2005 from BestBuy retail store and paid $699 up front and there is a $100 mail-in-rebate making your final cost $599. Beware of bad and/or stuck pixels on this one. I had to exchange mine twice in order to get a flawless one. Depending on the store size, BestBuy may only stock 3-10 units per shipment.
Other than that, Sony's XBRITE technology puts this LCD in a seperate class from all the others. The XBRITE does result in a screen that reflects light but it is only noticeable when the power is off or viewing dark backgrounds like this forumn. This LCD is very bright. Eventhough I am using the analog input, the image quality looks as if I was using the DVI input of a standard 19" 300cd/m2, 25ms LCD. Its displays very crisp fonts. The reds are redder, blues are bluer, etc.
It comes with a 3 year warranty from Sony. Disregard what the sales consultant says about it only having a 1 year warranty while they try to sell you a 2 or 3 year extended warranty wich starts on the date of purchase.
In the box is the usual along with an analog cable and a DVI cable.
The OSD menu is a bit easier than most to navigate since there are four buttons to use versus three. There are three presets named: GAME, MOVIE and PC. Each preset can be modified and memorize. There is a button dedicated to the selection of the presets.
The only adjustment featured is the ability to lean the unit more forward or more backward. This is acomplished by a hinged stand on the back which holds the unit upright by spring tension in the hinge and a roller on the bottom of the stand that is in contact with your desk.
Is there anything else you would like to know?
