This, to me, is the most undesirable type of hardware work. Replacing the motherboard in a computer made by a major manufacturer. In this case, a Sony Vaio VGC-RB40. I ordered an Asus P5L-VM and have everything installed fine (I think, anyway), but the front panel connectors to the Vaio aren't matching up with the board's pin layout. Sony decided to lay out the power/led/reset/HD led/speakers in a standard USB layout, five pins on top four pins on bottom, whereas Asus has them spread out and certainly not in a brick like the case's plug.
Anyone have any suggestions? For one, I can't figure out which pin on the connector corresponds with which function, and in order to find that out I need to be able to see the back of the front panel, which has been riveted shut so that I can't get access without a dremel. I'll even settle for just the power switch connector but can't seem to hit the right combination of pins.
What I'd *love* is the type of board Sony put in the Vaio VGC-RB40 so that I can see the motherboard manual. Otherwise I feel that I'm up a creek without a paddle.
