Sony Finally has good LCDs?
jhtevans
I was cruising around looking for a decent 17" LCD and it looks as if Sony has finally rolled out a decent unit. Below are the specs - anyone know how this performs in reality?
SDM-HX73/B -- $ 619.99
http://www.sonystyle.com/is-bin/INT...ProductInformation-Start?ProductSKU=SDMHX73/B
Specifications
• Model / Color: SDM-HSX73/B [Black]
• Panel Type: TFT Active Matrix
• Pixel Pitch: 0.264 mm
• Viewable Image Size: 17.0"
• Stereo Speakers: Yes with Headphone Jack
• Tilt Adjust: -5° to +20°
• Horizontal Scan (kHz): 28k - 80 kHz
• Vertical Refresh (Hz): 48 - 75 Hz
• Native Resolution: 1280 x 1024
• Brightness & Contrast (max): 400 cd/m2; 500:1
• Viewing Angle (Horz./Vert.): 140° / 160°
• Response Time (Rise/Fall): 16ms
• Color Temperature Control: 9300K, 6500K + USER
• Plug & Play: DDC-2B
• Power Consumption: 45W (max)
• Power Standby: 1W
• Internal Power Supply: Yes
• Input Connector(s): Digital (DVI-D)
Analog (HD15) x2
• Dimensions (W X H X D): 16.4" x 16.5" x 9.3"
• Weight (Display): 14.3 lbs
• Accessories:
AC Power Cord
Cables: DVI-D, HD15, Audio
Limited Warranty Card
CD-ROM for PC/MAC: User's Manual, Utility Files, Display Adjustment Tool
Quick Setup Guide
• Limited Warranty: 3 years (Parts, Labor, Backlight)
