sony dsc-t7 for 347 shipped
jfish
$449 - auto 15% off - $35 off coupon = 347
35 off coupon: $DF97G9KXSNJWW
For those of you who don't know what a DSC-T7 is, like myself, before now.
SONY CORPORATION DSC-T7 Cyber-shot Digital Camera
http://accessories.us.dell.com/sna/...y_id=5970&first=true&page=productlisting.aspx
Color Support: Color
Digital Zoom: 2 x
Optical Zoom: 3 x
Resolution: 5.1 Megapixel
Special Effects: Black & White, Sepia
Depth: 1.5 cm
Features: AF illuminator, flash +/- compensation
Features: Aspherical lens
Height: 6 cm
Weight: 134 g
Width: 9.2 cm
Additional Features: Audio recording, direct print, USB 2.0 compatibility, built-in speaker, RGB primary color filter, auto power save, digital noise reduction, date/time stamp, DPOF support, display brightness control,
Auto Focus: 5-Area Multi-Point
Auto Focus Points (Zones): 5
Available Body Colors: Black, silver
Cable(s) included: 1 x USB, 1 x Audio/Video
Camera Flash: Built-in flash
Connector Type: USB 2.0
Digital Storage Media: Memory Stick Duo™, Memory Stick PRO Duo™
Digital Video Format: MPEG VX
Dimensions (WxDxH): 9.2 cm x 1.5 cm x 6 cm
Display: 2.5" 230K Pixels TFT Hybrid Color LCD
Display Form Factor: Built-in
Display Format: 230,400 pixels
Effective Flash Range: 0.1 m - 1.6 m
Effective Sensor Resolution: 5,100,000 pixels
Expansion Slot(s): 1 x Memory Stick PRO Duo
Exposure Compensation: ±2 EV range, in 1/3 EV steps
Exposure Metering: Multi-segment, center-weighted, spot
Exposure Modes: Program, automatic
Flash Modes: Auto/Forced, On/Forced, Off/Slow Synchro
Focal Length: 6.33 mm - 19.0 mm
Focal Length Equivalent to 35mm Camera: 38 mm - 114 mm
Focus Adjustment: Automatic, manual
Image Storage: Fine JPEG 2592 x 1944 : 12 - with 32MB card ¦ Normal JPEG 2592 x 1944 : 23 - with 32MB card ¦ Fine JPEG 2592 x 1728 : 12 - with 32MB card ¦ Normal JPEG 2592 x 1728 : 23 - with 32MB card ¦ Fine JPEG 2
Included Accessories: NP-FE1 Rechargeable InfoLithium® Battery, AC Adaptor, Camera Desktop Display Stand, Interface Adaptor, Camera Holder for Tripod, A/V and USB Cables, Neck Strap, MSA-32A 32MB Memory Stick Duo™ Media, Memory Stick Duo™ Adapter
Lens Aperture: f3.5 – f5.6 (W), f4.4 – f8.0 (T)
Lens Construction: 11 Elements in 8 Groups, 3 Aspheric Elements, 1 Prism
Lens Manufacturer: Carl Zeiss
Light Sensitivity: ISO 100, ISO 400, ISO 200, ISO 64, ISO auto
Macro Focus Range: 1-50cm
Max Operating Temperature: 40 °C
Max Shutter Speed: 1/1000 sec
Microphone: Built-in
Microphone Operation Mode: Mono
Microphone Technology: Electret condenser
Min Focus Range: 50 cm
Min Operating Temperature: 0 °C
Min Shutter Speed: 1 sec
Optical Sensor Resolution: 5.1 MP
Optical Sensor Size: 1/2.5"
Optical Sensor Type: Charge Coupled Device (CCD)
Product Type: Digital Camera
Red Eye Reduction: On/Off
Self Timer: 10 seconds
Shooting Modes: Frame movie mode
Shooting Programs: Landscape, hi-speed shutter, twilight portrait, fireworks, soft snap, twilight mode, magnifying glass, candle, beach, snow
Software: Drivers & Utilities, Sony Picture Package, ImageMixer VCD2
Still Image Format: JPEG
Type: LCD display - TFT active matrix - 2.5" - color
Type: Microphone - built-in
Type: Zoom lens - 6.33 mm - 19 mm - f/3.5-4.4
White Balance: Auto, Daylight, Cloudy, Fluorescent, Incandescent, Flash
White Balance Presets: Incandescent, fluorescent, cloudy, flash, daylight
Zoom: 3X Optical / 2X Digital / 6X Total / 12X SmartZoom™
Zoom Adjustment: Motorized drive
Continuous Shooting Speed: 1.1 frames per second
Flash Memory: 32 MB
Flash Memory: 32 MB flash - Memory Stick Duo
Self Timer Delay: 10 sec
Video Capture: 30 fps - 170 sec - MPEG - 640 x 480 - with 256MB card ¦ 16.6 fps - 80 sec - MPEG - 640 x 480 - with 32MB card ¦ 8 fps - 1360 sec - MPEG - 160 x 112 - with 32MB card
Sensor Resolution: 5.1 Megapixel
Product Description: Sony Cyber-shot DSC-T7 - digital camera
Power Device: Power adapter - external
Operating System Support: MS Windows XP, MS Windows 2000, MS Windows ME, MS Windows 98, Apple Mac OS X 10.1, MS Windows 98 SE, Apple Mac OS X 10.2, Apple Mac OS 8.5.1, Apple Mac OS 8.6, Apple Mac OS X 10.0, Apple Mac OS 9.0 -
Total Pixels: 5,300,000 pixels
Supported Flash Memory: Memory Stick Duo, Memory Stick PRO Duo
Cables Included: USB cable ¦ A/V cable
Peripheral Devices: USB port, CD-ROM drive
Supported Battery: 1 x Li-ion rechargeable battery - 450 mAh ( included )
Supported Battery: Sony NP-FE1
Supported Battery Details: 1 x Li-ion rechargeable battery - 450 mAh ( included )
Pretty good deal, I got mine for $407 shipped like 6 months ago (which stil isn't bad). It's a good camera, short battery life but VERY SLIM.
I love my T7 of course I paid $500 for mine when it first came out. And may I say I have taken so great shots cause this thing is small enough to carry every where. And as so as you flip the lens cover down wait a second and you are good to start shooting. So you really can pull it out open the cover as you are getting it out and be ready to take a picture before most people can even think about trying to find their camera. But I will say one that they are durable. I have dropped mine a couple of times. Once was my fault but the other some one was holding it and dropped it. It took the hit in the corner and you would never know it have even it the ground. So I may just buy another one to take keep for if any thing happens to mine.
