Hi to everybody!
In this link you can d/load the manual:
http://www.scooterclub-nolimits.it/E500.pdf
The monitor had a problem.
I had fixed a previous, overbright problem using WinDAS. I thinked that I
can solve also this problem of distorsion of the image, but it is not
possible via software.
The problem is rappresented in this paint:
http://img181.imageshack.us/my.php?image=monitorjx9.jpg
The monitor had a distorsion on the top and bottom right corner: in this
corner, the image is also out of convergence and out of focus. If i set
focus (in FBT) and convergence (using OSD) to see clearly in those corner,
the image is, f course, out of convergence and out of focut in the ather
parts of the screen.
The screen seem "hitted": like the regulation of trapezoid, but in the top
and in the bottom part of the screen...and is impossible to correct it using
the OSD regulations.
Do you have any tips..?
I think that there is a problem in deflection circuit, but I hadn't find any tips for my model (G1 chassis)...
