Sony 21" Flat CRT
I need a new monitor and would like to get a 20"+ flat CRT. I am leaning toward the Sony CPD-E540/B or the CPD-G520P. Anyone have any feedback on either model? According to Sony's website, the only differences, other than aesthetics, between them are that the 520 has two inputs and a little more resolution. That doesn't seem like much for a $200 difference in price. The monitor will be used primarily for gaming and will be hooked up to a 9800XT.
Are you buying them straight up new or refurbished? If you are looking at refurb, I'd go for the Sony G500. If you are buying one brand new, get the Iiyama or NEC 22"..they are about $600 and have some seriously nasty specs....like 1600x1200 @ 109hz.
