I am attempting to setup a VPN for some of the users at our company. We have a SonicWall TZ170 firewall. I have the VPN setup but am running into some issues and was just hoping that hopefully someone on here would have some experience with the issue.
I can connect to the VPN but it will not assign an IP address. I have literally gone through and redone the the setup according to the manual at least 4 times. I have DHCP enabled on the firewall and given an adequate amount of available addresses, but the VPN client hangs on the "Acquiring IP" status.
The VPN client's log says: "Failed to renew the IP address for the virtual interface."
The Firewalls log doesn't seem to have any errors showing up, and until I turn on the "DHCP lease" option the client connects to the VPN but of course doesn't receive an IP address. When "DHCP lease" is turned back on the client doesn't make it all the way through the connection phase.
It is obviously an issue with the DHCP on the firewall but I have no clue where to start. I've followed the guide from SonicWall to a T, with no results.
This issue has seriously started to make me wonder if I chose the right career path...(about to graduate in May)
