Couldn't resist to pick up this Antec Sonata @ Fry's for $59 after rebate
. Though the case is very quiet, air intake side is less than desired. I notice after I took out the removable 3 1/2 bay (no flappy for this set up), the air flow out of the back 120mm is much imporved, and case temp drop 3C. So I made a bracket with the cut opening, spice up the look a bit...
Add a fan behind the tunnel...
On a hot day, just open the door for more vent...
When quietness is needed, close the door...
