So I built a semi-budget system. Wasn't totally looking to save a lot of money, but did not want to blow the bank. Got lucky with some decent deals.
My main issue is the Sonata III Case.
Specs
did not pick these up from newegg, just using the links)
Case: Sonata III Comes with a 500w EarthWatt PSU
Mobo: Gigabytega-p35-ds3r
Processor: Q6600
VideoCard: XFX 8800GT
RAM: OCZ Gold 2x1gig
OS: WinXP (Temporary; Once I get Vista I'll replace RAM with 2x 2gig sticks)
I am hoping to clock the CPU to 3.0 it is a G0 stepping. I do not plan to OC the Video. I might, but might not tighten the timings on the RAM a little.
I am also trying to decide which heatsink I should get. I'm trying to avoid $50 heatsinks though. (I know that sounds trivial after buying everything else)
My concern is the case and PSU. The case has space for two 120 fans, but one is behind the HD Rack. Also will the PSU be able to handle that system? I'm am not sure if this will be enough cooling for what I am trying to do.
Has anyone had any experience with the Sonata III Case or know of any easy mods that might help increase air flow? I am fairly new to OCing/cooling, but I clearly understand the hardware.
Thanks your for time.
____________________________________
UPDATE-------------------------------------------------
Looking at picking up a Antec P180 and using the 500w Earthwatt PSU. Which has a lot better air flow. Hopefully this will fix my concerns with cooling, also am going to pick up the 4 gigs of ram now rather then the 2gigs.
Thanks for all recommendations. Probably would have fried something if I put it together in the Sonata III, heh.
How do people like their P180s? I'll just have to do some origami work with the wires.
Baraloo
Specs
Processor: Q6600
Baraloo
