400+whpwrx
- Sep 27, 2003
I am looking to sort out what the best option is for storage system.
Current hardware
dual opteron sun box (2gb, scsi)
Requirements
Lots of storage
Online expansion/rebuild capability
Ability to have multiple systems access filesystems (ability to create multiple filesystems, this is going to be done by ZFS on solaris 10)
Hot swap drives if they fail
Raid6 (unless someone else has a better idea)
Ability to do up to 16-20 drives)
Filesystem has to be able to hold lots of files (ZFS again) and have good IO for DB back ends and the like.
Issues in question
Should i build one file server and then use NFS from the multiple systems to it? (comes down to how good is NFS for housing DB's etc)
Or should i build one large box with a massive array and use Solaris 10 zones to partition the box into multiple "instances"? (i would be using zfs on solaris 10) Note this option would mean spending more on MB/CPU/Ram vs building a straight up Fileserve.
Hardware im looking at
CM Stacker for the case
Supermicro drive cages (like the one posted in the terabyte club thread)
areca Raid card (16 or 20 port not sure yet, any input into pci-e or pci-x would be awesome)
Hardware i still need to sort out
Power supply (needs to be able to handle 20 drives or so, if i build a SMP system this will be a large expense as the power req goes up)
Hard drives (best price per gb and performance?)
My thoughts
To keep costs down i was just going to swap the Sun systems mobo into the CM stacker and then purchase more ram (it has 2gb was looking at adding another 2-4gb), and the drives and raid card.
Your thoughts? I am still in the planning stages at this point, but i will most likely pick up the case and drive enclosures soon as i dont see prices on those two items going down to much in the next month or two.
Current hardware
Requirements
Lots of storage
Issues in question
My thoughts
