Sometimes shutting down the system restarts it.
kowkow
Hi
my rig:
Athlon 64 3200+
Sapphire PE-A9RS482M (Socket 939) with the latest BIOS from the board's web-page.
2*256MB DDR400 RAM
Cooler Master 380PMSR (12V @ 16A)
Now the problem is: what ever operating system I use Linux (Fedora, Slackware, Ubuntu) or one of the BSDs (FreeBSD or PC-BSD) or Windows XP, there are times when shutting down the system restarts the computer.
The trouble shooting that I've done:
Used another SMPS.
Result: Problem doesn't go away.
Memtest86(ed) both the sticks for 12 hrs.
Result: Pass
12 hrs. of Prime95. Torture test with lots of RAM test option.
Result: Pass
If it helps there's another thing that my motherboard does (sometimes) when i shut down the system: it leaves the num-lock light of the keyboard on.
Thanks a lot in advance.
I've tried things like changing ACPI suspend type from S1 to S3 to S1&S3, C2 disable/enable, Cool and Quiet enable/disable and some other options, but nothing seems to help.
I've also tried disabling ACPI altogether and booting into linux with APM, but to no avail.
