There is something wrong with my machine, and I can't determine the problem. It started yesterday - suddenly everything started to be very sluggish - opening tabs in browser takes ages and some of the pages don't load properly - especially those with lots of Java and Flash
Launching application and games, even starting the windows take now more time than it used to, and nothing works smooth any more.
I installed my ZxR on Friday, so I'm suspicious about drivers, but it should bork the machine just after installation, not now. The only thing that got installed was Java update.
At first I blamed the delay, becuse windows wanted to wake my HDD up, before launching any program, however after disconnecting it, it works same sluggish. I also run a Samsung MAgician optimisation tool on SSD, cleaned temp, deleted apps that I don't need - also have the 69,5 GB free on my 256GB SSD.
Restored CPU/RAM to normal speed, nothing got better. I think it might be either RAM or SSD or just Windows needs reinstallation.
Any ideas what can be happening?
