Somethings very very wrong with PC
Laike
Well, I figured there was something wrong with my PC, and now I'm sure tehre is. The CPU seems to be running hotter than it hsould be (I'm just waiting it burns out it seems right now) My 3dmark scores are... well, horrid to start with . My BF2 has been running like crap, there are a couple of guys who are runnign worse systems than mines, but are pulling offw ay better FPS. I did a 3dmark06, and this is my result
Total 3376
SM2.0 1373
HDR SM3.0 1241
CPU 1662
I ran the test on everything default except the resolution is at 128x1024. I'm pretty sure there's something wrong with my system, but I'm not sure what is wrong with it.
BF2. same resolution as earlier, everything on high or maxed out in game:
http://img403.imageshack.us/img403/5443/allhigh8dt.jpg
My specs
AMD 64 4200+ X2
Asus A8N SLI
eVGA 7600 GT OC
2g Corsair Value Select
530w Ennermax PSU
Creative Xfi ExtremeMusic
80gb SATA
120gb WD
Windows XP Pro 64bit
I have the correct page files, I've defragged til diskkeeper says HDD is running perfect. No viruses, spyware, the computeris only a month old, tops. I tweaked the PC out, updated the firmware, it's helped slightly, but still hasn't helped much. Am I just over rating the capabilities of my PC? or should I be bringing this thing to the shop and figuring out what part is about to die on me?
Look at this review: http://www.legitreviews.com/article/312/1/
Your 7600GT is giving you what it's supposed to. I don't see what the problem is. The BF2 frames are about correct for the 7600 as well.
What temp is your CPU running to cause you alarm? Are you overclocking the CPU and/or 7600GT?
There's nothing wrong with the performance of you PC.
