TeleFragger
- Nov 10, 2005
Ok so I have a laptop that is a
Acer Extensa 5620
not a bad unit, was free and have been enjoying it...
however it has a common problem with the lcd screen rear lid piece cracking by the hinges.. it was just cracked but now it is cracked all the way through.
what is a good epoxy based to use to glue something like this back together?
I can hold the lid up and it goes so tight back together where epoxy would work ....
i was going to use jbweld as I have used that on other things with great success.
was going to sand the area with rough sand paper and go over it in a large area to create a good bonding area... but looking for opinions...
fyi i checked ebay..
bought a new battery for $18 - reasonable
bought a new dc internal jack with cable for $4 - reasonable
was going to buy the rear screen lid but $120-$150 USED - NOT REASONABLE!!!!
Acer Extensa 5620
