Something is wrong with Fable the lost chapters
rcf1987
OK I got this game, heard it was fun, I put the res on 12/10/32 a 85 refresh rate with all settings turned up when I go to start playing it turns everything down to lowest settings and a res of 640/480/16 and a refrsh rate of 60 and I am missing part of the screen WTF.
You know, I had the same problem the first time I played it. Can't tell you exactly what I did to fix it, but it looks wonderful now. Check to make sure your aspect ratio is set correctly and try to adjust one setting at a time for starters. Maybe if you change a setting and restart the game? I wish I remembered exactly what worked, but I'm sure it was something simple like aspect ratio or something.
I have a 2005FPW in case that helps any.
You're setting the shadow setting to something unsupported by your card. turn it down one notch and your settings will stick. Fable uses sm3.0 for shadowing
Worked thnxs
