Something died spontaniously?
Rusty4560
Alright here's an odd scenario.
This morning I was sleeping and woke up (for some reason) at like 5:30 to my computer shutting off. I assumed my house lost power so I didn't really think a whole lot about it. Then I got up for work at 7:30 and realized that I never lost power.
My computer randomly just shut off. I hit the power switch and the fans twitch and I get lights for about a half second. I go around to the back of the case, I have network link lights (so I'm getting some power) and I disconnect the power cable and wait a few. I come back plug the power cable in and it does the same thing as the first time.
I haven't had time to troubleshoot anything because I had to leave for work but I'd like to hear some suggestions on what I should check first or if someone has ever had something like this happen to them.
I'm hoping it isn't the motherboard and it doesn't seem to be the power supply do to the fact that there is some amount of power going to the machine.
Thoughts?
It ended up being the power supply. I have it RMAed. However now my machine locks up during post. If I hit tab to show post messages it stops after it identifies the memory. I've tried doing 3 sticks, 2 sticks and 1 sitck, Not quite sure at this point.
disconnect all of your drives from the motherboard and see if it still locks up.
Still freezes with the drives unplugged.
It seems to freeze at the splash screen with memory in the first memory slot. I took out the first one and it lets me view post messages. But still freezes right after......
Main Processor: Intel Core 2 Duo CPU 2.66GHz, 2 CPUs
Memory Testing: 3144704K OK (Installed Memory: 3145728K)
CPU Brand Name: Intel Core 2 Duo CPU E6750 @ 2.66GHz
Memory clock is: 800MHZ
DDR2 Single Channel Mode
Then it freezes
Freezing like that sounds like memory to me. You said you tried 3, 2 and 1 stick(s) at a time. Did you try each stick alone? Do you have another DDR2 system for testing? The PSU could have damaged the memory or motherboard.
I'm thinking the PSU messed up something. I've tried nearly every combination of memory sticks and it freezes in the same spot or before that. I'm going to try and see if someone would let me borrow their RAM for a quick test but I can't think of much else besides that. I wouldn't be able to run memtest because I can't get through POST so booting from something wouldn't be possible.
I just bought the memory and motherboard last August so I'm really hoping I don't have to replace it.
Definitely try to borrow some known-good memory, or take your memory to someone's place and try it there, or both. It sucks that the PSU may have taken something out with it. Hopefully it's the memory, at least that's cheap to replace and doesn't cause you any data loss.
Yea, tell me about it. I just bought the power supply on August 8th with a new video card. It was still under the newegg 60 day return or whatever.
I'd really hate to replace this motherboard. If it comes down to that anyone have a good suggestion?
Current Motherboard: ASUS P5N32-E SLI Plus LGA 775
try reseting CMOS also a powersupply can corrupt a CMOS when it goes down.
then yes disconnect everything but monitor and keyboard and test mem. reset memory also try again.
Thanks END.
I got it to boot.
When my IDE media drives are plugged in it seems to freeze during post and when one of my sticks of memory is in it does the same. So I have no media drives and 3gb of RAM in the machine right now..
So is it booting alright now? you said one of you memory sticks is this a usb type stick or one of your ddr sticks in a slot?
I took one of my 1gig sticks out. I'm running 3GB of RAM now. Also since my video card requires so much power and I didn't have the enough channels for it I had to combine 2 molex to make a 6 pin and combine the 2 6pins to make an 8 pin. So I don't even have enough channels to power my media drives anyway.
When I get the corsair PSU back I will drive the media drives again.
And yes it is booting and running stable now.
Reset CMOS, disconnected media drives and took at 1gig stick of RAM out. That seems to have done the trick.
Thanks again END
