Something in my computer died yesterday. I was switching slots for my memory to see if will allow it to OC more. Other combinations caused massive errors. So I put it back to what it was before and set everything in the bios to stock. I tried memtest and it failed (stock speeds for memory). Then it started giving tons of errors. My keyboard didn't work so I hit the reset button. This time though, it said "System failed CPU test."
How could it have killed my cpu? Could it be a motherboard? Ever since I got this mobo back from rma, it always errors in memtest at the exact same spot. I didn't think it was a problem because it was running very stable. So could this possibly be a problem with the mobo and not the cpu? I sure hope so because I have a FX-55. I got nothing I could test with. The cpu does get warmer if I leave it on. At boot, it was 13C and leveled off at about 25C in a few minutes. Room temp was probably around 10C.
