What I want to do is modify the earphone jack on my Logitech x520's
When the speakers are on, it plays, you plug in earphones and the sounds from the speakers cuts out (like it should) what I want to know, is how do I bypass the switch at that jack so I can make a remote switch.
What I do know is that if I plug the extension cable in with no load on it, it still cuts out the mains, meaning the must be a physical switch in there some where.
I want to be able to leave an extension earphone cable plugged in all the time and make a remote jack that will basically do the same thing closer to my chair, however, I dont want to scavenge the jack out of the speaker set its self (i.e. de-solder that jack, solder extension cable in its place, solder jack on other end of cable) I would rather buy a second jack and be able to unplug the extension for mobility reasons.
The switch is plastic enclosed inside the speakers, so I cannot easily see what is going in inside the mechanism.
I guess what Im looking for is a switch wiring diagram and part number form popular vendors the rest I can figure out.
