This is where I am at.
Purchased a Samsung UN32EH5000 (32" 1080p LCD LED), it is naturally a 60 Hz monitor however it has a True Motion feature. When I enable Vsync caps the FPS at 120 instead of 60.
- I get input lag playing PC games unless I use "PC" Mode
Ok fine, not sure what PC mode did to take my input lag away but it helped.
- However, I ALWAYS play my PC games with Vsync enabled because my PC is pretty good which = super high frame rates and massive screen tearing.
Ok, so when Vsync is enabled and it takes my FPS to 120 I get MASSIVE input lag
I can only guess that True Motion has something to do with this, however in the options menu I can only find LED Motion Plus, and have tried this option both on and off with Vsync and neither way has helped.
The input lag makes games unplayable, I can play them smoothly with Vsync off however having 500+ FPS gives me annoying screen tearing.
I tried Samsung's helpline but they weren't able to help too much I think because no one I talked to was familiar with using their LCD TV with PC Gaming.
Help Please :]
Help Please :]
