Someone please help me! Blurring with a CRT
iceknight
Ok here is my problem...
Whenever I change my refreshrate above 60hz, I get blurring. 70hz has almost no blurring, 72hz has a little blurring, 75 hz has noticable blurring and 85hz has significant blurring. According to the specs of my monitor, it should be able to do 85hz at 1280x1024 res and it can't even do 85hz on lower resolutions than that. I get blurring when i'm scrolling through a website and the text shakes and blurs and I get blurring when I turn in a FPS. It's not nearly as smooth as when I have it set at 60hz but 60hz strains my eyes. I have tried everything....refreshlock program, nvidia driver refreshlocks, V-sync, lowering resolutions etc, nothing helps. All I can think of is that the monitor may be faulty or something, which sucks bigtime.
I don't know what to do and i'm hoping someone here knows a magical cure because i'm really bummed out. Any help is greatly appreciated.
My specs are:
P4 2.8ghz
ASUS P4P800 MOBO
1 Corsair Value Select Ram
Geforce 6800 GT
Monitor: NEC/Mitsubishi Diamond Pro 930SB CRT Aperture Grille 19"
Sounds fecked t me. Sorry. Have you e-mailed NEC ? tell them , or look on there site. If no help there, try the windows newsgroups, or some other, i know its sounds like a monitor problem but cud b anythin.
Have you tried a monitor calibrator? may help. Just tryin t think of anythin u cn do. Apart from that, have u tried the ol` percusive recalibration. Jus a wee nudge tho.
Not sure what precursive calibration is, could you elaborate? :).. I adjusted whatever I could from the monitor menu to the best of my skill.
Lol, it means as in hitin it, but dont do it cus i said tho.
I`d definatly try lookin around as much as u can on the web, then flirt back here, post on a few sites, go t google groups take a look round, it really is just a case of keep on keepin on, as i found out with a recent problem of mine.
I have a Sony 21" monitor which is doing something very simmilar.
After being on hold for over an hour (great customer service :rolleyes: ) we determined that the monitor is just dying..
So.. I am to have a refurbed monitor sent from them to replace this one.
Now.. I just have to wait for freakin ever until it arrives what with the hurricane and all.
SO.. I would contact NEC and hope your monitor is still under warranty
Good luck
D.
My specs are:
P4 2.8ghz
ASUS P4P800 MOBO
Geforce 6800 GT
How about a bit of diagnostic work first.
Did this problem just start? Or has it been building?
Did you add or subtract any hardware and or software before this problem started?
If you take out what you changed does it get better?
Have you un-installed your video drivers and started from scratch?
Have you tried your monitor on another computer?
Have you checked to see if your monitor settings are even close? As in contrast almost all the way up, brightness about half etc.
Give that stuff a shot first.
Luck
Yea I pretty much tried all that. I reformat and install on a regular basis though, to keep my computer running clean. The last reformat was a week ago and I know this has been a problem before then. For all I know, this monitor could have always had the problem. This brand of monitor is known for being very good but being a crapshoot because many of them turn out to be faulty. I've heard about people having to repair or send back their monitors several times. I already sent this monitor back to get repaired once because it kept clicking on and off in amber mode and wouldn't even display anything after 3 months of use.
Anyways, I recently discovered that even though you set the refresh in Windows to a particular refreshrate, it doesn't mean that in-game, you are getting the same refresh rate. With WinXP, you get 60hz default unless you overrride it, which I recently did and I noticed that my monitor isn't able to handle anything above 60hz without blurring. I sometimes got headaches after playing games for a while and this is the reason, it's not good for you to use a 60hz refreshrate. I also want to play at 85hz because you get a nice boost in frames.
I've posted on a few messageboards before this and nobody really knows what to do.
If all else fails then i'm going to have to get on the phone with NEC and just have them send me a reburbished one, I still have my monitor under warranty since it's only 7 months old. This montor has really been a pain :( Wish I read more reviews on it and decided to go for a more reliable monitor.
Blurring at high res seems to be a common affliction for these monitors. There should be some adjustable pots on the left side near the rear of the cabinet, one for brightness and two for focus. Try messing with 'em and see if it helps. They're really sensitive, so adjust them slowly. You'll need a flashlight to find them and a screwdriver to get to them, but trust me, they are there. Make sure superbright mode is off, too.
Hope this helps...
Try a new video cable. That is of course if you can detatch yours. Could be something as simple as your cable is shot. Of course don't try el cheapo cable. You'll need a fairly good one. Double ferrites, good shielding.
