Someone help me remove service pack 3
natty
I installed a windows XP disk that came already loaded with service pack 3. But one of the applications I use won't work with sp3. So is there any way to just remove sp3? Or do I have to start from scratch and use a windows XP disk that doesn't have it.
If you go to control panel ---> add/remove programs, does it show SP3 at the bottom of the list? If so, just uninstall it through that.
If SP3 is slipstreamed in, you can't remove it from Add/Remove. Sorry.
Normally you could run the spuninstall from the hidden folder under C:\Windows. However with a copy of Windows with SP3 already installed, there's really no way to remove it that I'm aware of.
Right click on the shortcut to the application you are attempting to run -> properties.
Change the compatibility level to XP SP2?
You can do that in Vista, but there's no option for XP SP2 in XP itself. I was just looking at that on my XP SP3 machine. Only 95/98/NT/2000 compatibility modes.
All that headache because one program "doesn't work" with SP3? What program?
Torq has the first post that makes sense..
What's the program and why doesn't it work? How doesn't it work?
Are there no alternative programs?
Why not write to the makers of the program and give them a bug report and have them fix it to work under SP3?
Answering his question is hardly a post that doesn't make sense. The guy asked how to remove SP3, not how to get his app working. :rolleyes:
True, but the aim is to run the incompatible program, not to uninstall SP3 because it's a horrible service pack. Seeing as uninstalling SP3 is impossible in this case, the OP will either have to reinstall from a copy of XP without SP3 slipstreamed, or find some other way to get the program working.
I don't gold plate nor did I say uninstall SP3 was the answer to fix a broken application. He asked, and I provided an answer. If he wants us to read further into it then he can ask. :)
Often, the dilemma is that many people choose to remove rather correct an issue. i.e. If I remove Limewire, I won't get viruses anymore or If I reinstall XP, I'll see my issue corrected. Most of us here usually go about the method of fixing the issue first before resorting to more drastic measures that take our time away from enjoying the technology we're fond of one way or another. I hope that natty will see that if he/she decides that a corrective action is far more effective than a knee jerk reaction, the benefit of figuring out what is causing the application to not work will provide a clearer reason for its failing.
Anytime you are doing support-type work, you look for the best solution, not always just the one a person is focusing on.
I am well aware how to do support work thanks. I do it daily and have been for 8+ years and I'd rather eat glass than reinstall the OS. However the post doesn't provide any information as to what the application is, how much time he's invested trying to fix it, importance of fixing it, or anything that would further need us to provide anything other than the question at hand.
I don't make assumptions and I deal with the issues based on the information at hand. He asked how to remove the SP, and I explained it to him. Again, if he wanted anything further from us perhaps he wouldn've provide the appropriate information for us to provide him a path for resolution. I never said it was the best solution or that I subscribe to his method of troubleshooting. You've all provided the other way to deal with the issue when that wasn't even the reason he bothered to post. Agree to disagree.
No, but how often do you see threads on here where the OP doesn't even bother to give enough details for a solution, so a quicker, more viable solution is skipped? Later on in the thread, when the OP would give more info, the situation changes. You're getting all worked up trying to defend your answer, to the point you are missing what's right in front of you. No one gave a bad, or unhelpful answer. No one is pointing fingers. The OP didn't bother to give a simple piece of information, so no one can be sure if a reinstall is needed, if SP3 needs to be removed, or if there is a simple fix. No one knows this, due to missing information, so there's no point in arguing about it.
Although he asked about uninstalling SP3, there isn't any reason why alternatives can't be suggested that could result in accomplishing his goal of getting his program to work.
Show me where I stated the contrary and I'll eat my words. I wasn't in defense mode until the poster above stated that all previous posts prior to the one above his didn't make any sense. Either way I'm done with this thread. It's turning into quite the bandwagon. Enjoy, maybe the OP will actually post back.
