Someone help me figure this out...
AY786
Well basically i have a main TV in my living room which everything is hooked up to including satelite (sky), dvd players etc, however, i have just bougt another tv which will go into the dining room. this will be wall mounted. How would i go about connecting this up as the main areial point is in the living room already connected to one TV (what would i need).
I assume by "ariel point" you mean that your sattelite box is in your living room...you need to contact your provider (Sky) and see what kind of system they use for multiple tv's. If the distance is not too far and you are up for the challenge you could use a splitter and run coax throught the wall..but then you would have to go to your living room to change channels. I will let others comment on wireless media extenders and such (it can get complicated and expensive) but personally if I were in your situation I would simply get another sat box for the tv watching in the dining room and leave the dvd's and such for the living room.
