some WC suggestions?
Absentee
well i just bought this kit:
here
i didnt want to nit pick about what i was gonna get and i had a limit of $160 (including shipping)
im also a semi-noob when it comes to WCing...ive read alot but ive never done it.
so i went for this since it has a good pump, a decent radiator that will fit in my case without cutting the top panel. so the radiator will go in one of the two rear 80mm holes in the back of the case
heres where i need my first suggestion...i plan on mounting one fan on each side...
should i place one fan on the outside pushign air through with the radiator OUTSIDE the case with the second fan inside the case pulling in?
or should i put the radiator inside the case with the fans in the same push/pull setup?
either way im pretty set on the fans pulling air INTO the case since right now..if i put my hand on the case..its warm to the touch...and i dont wanna put that hot air through my radiator...
2nd suggestion i need is what order should i put the components in
pump>radiator>cpu>(chipset block ill add later)>)vga block im adding later)>fill&bleed kit/resevoir later on>back to pump?
is that good?
like i said...im a n00b to WCing and would just like some suggestions
good luck on ur setup. i wouldnt prefer getting the kit, but u got it already :)
ty...i wouldnt of either but it was cheaper...cus frozencpu.com was having a sale.
and still is ;) ;)
