Some very basic Win 7 questions....
Johnny78
I'm fairly tech savvy with regarding to hardware but as far as software goes, (esp. OS) I'm fairly clueless so I was wondering if you guys could help me out with a few basic questions. I'd like to finally upgrade from XP to a newer OS. Vista never seemed quite compelling but with all the fairly good feedback regarding Win 7, I'd like to finally upgrade my OS dinosaur. Win 7 64bit seems to be the way to go as far as most of the positive feedback is concerned.
I know that I'll have to do a clean install since I'm running XP and not Vista. Not a big deal since I planned on getting a couple of velociraptors to run in raid 0 and I'd figured I'd do everything at once. My questions are simple: what exactly are people running right now since I read the official release date for Win 7 is Oct 22nd? Is it some beta version of Win 7? Will that differ from what is released on October 22nd?
Secondly, (and this is even more basic) but where do you recommend that I purchase a copy of Win 7? Do I have to wait until Oct 22nd? I'm a little confused by all the different prices on newegg.
Anyway, thanks for your input.
Most people are running either the Release Candidate that was made available to the public (or one of the builds leaked afterward that were so widely available on torrent sites), or the final version (aka RTM) that has been available to Technet and MSDN subscribers since about the beginning of August. The Release Candidate is just that, a build (or series of builds if you are talking about the leaks that were so rampant) that was post-beta (i.e. feature complete) but made available for testing to work out any final bugs. The RTM is the final code and exactly what will be on retail/OEM DVD's when available to the general public on October 22.
NewEgg has alway been my preference for purchasing hardware, and sometimes software like operating systems as well (I got my copy of Windows 7 from Technet, so no need to purchase here this time). If you can find a better price somewhere else, though, I'd say go with the cheapest price you can find for the version that you are looking to install.
I for one am running the final retail version of Ultimate x64 via my Technet account, and just picked up another free copy of Ultimate at launch event yesterday (after enduring 4 hours of god-awful lecture).
If I had to wait until the 22nd of October (the horror!) to install Windows 7 and I had to pay for it I would jump on Home Premium x64 for $99 on Newegg:
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
The rest are here:
Most of the legit copies floating around are from the ACM/IEEE academic version that were released briefly for students. There's also a copy, I believe, on MS's Technet if you have a subscription. MS has the Ultimate Steal type thing for W7 Pro/Home up for 30$ for students who didn't get the ACM deal. Finally, there's a trial version of W7 Enterprise.
Those versions above are RTM, which means it is the same version that will get shipped on Oct 22.
Newegg-type OEM versions are going to be the version that most non-students are supposed to purchase. If you can't get a student version somehow, there were pre-order type version that were slightly cheaper than the regular OEM, but that's about all that I can think of at the moment.
Running final (RTM) Windows 7, obtained via TechNet. I'm running all 'versions' other than Home Basic, and also a mix of 32-bit and 64-bit installs.
Recommended?
Home Premium, if you don't need domain join connectivity for work purposes or XP mode for productivity apps compatibility. Professional if you do need that. Ultimate is a wank. It more or less adds only BitLocker and Language Packs to the 'Professional' feature set.
Which 'version' is best for you depends upon what you use the machine for.
