I kinda asked this in the overclocking forum, but I thought i'd repost it in here and be a bit clearer in my question:
I've done some overclocking in the past but it's been a while, so I need a bit of a refresher.
I'm building an E6300 Core 2 Duo system for overclocking/gaming. It'll have 1gb x 2 of Corsair XM2 DDR2 800 ram.
Anandtech used this CPU and got the FSB up to 370mhz (from 266) on stock cooling and had a stable system at 2.59ghz. I'm getting a cooler that's a bit better than stock and a fan-full case, but I'd basically just like to get what they did to keep the ram stable at such a high FSB speed. I told myself beforehand if I got between 2.5 and 2.6ghz, I'd be happy so a 370mhz FSB is perfect. The thing is, they didn't provide any information on what they did to the ram speed to keep the system stable.
My question is regarding that very idea. I really don't know how the FSB relates directly, or indirectly, (or whatever) to ram speed. What can you do with a 266mhz fsb that will yield the DDR2 ram speed of 800mhz...or is that just a NUMBER not really meaning 800mhz? If I have the ram in my system set up at its default settings and then I push the FSB to 370mhz, what will that do to the ram speed? I don't have much faith in ram staying stable much past its default clock.
I don't really have any desire to overclock the ram. I'd rather that IT just stayed stock speed and if I want to mess with it later, I can do it then. Right now I'm just concerned with the CPU speed.
Can anyone offer a good explanation or a link to one? Thanks for any help you can give!
My newegg wishlist: https://secure.newegg.com/NewVersion/WishList/MySavedWishDetail.asp?ID=4304932
