mac_cnc
- Oct 14, 2000
A friend of mine had an issue and I wanna help him. here is a copy of his email:
I need some advice.
I purchases some used SCSI drives and I am having a problem getting them to work.
They are 80 pin seagates and I am using a 80 pin to 68 pin adapter.
I have gone through all of then manuals (for the controller and for the drives) and they should work.
Everything seems to be compatible (controller, drives, and terminator).
the drives are used and could be bad, but it seems unlikely that all four would be junk (i could see one or two)
I have been trying the drives one at a time and they are the only items (other than the terminator) on the bus.
Now, here is the thing I cannot figure out, If I apply power only to the drives, they will spin up; but when they are connected to the bus, they will not spin -up. I am thinking that it must be a configuration issue. But, I don't know what to try next.
Any ideas?
I need some advice.
Any ideas?
