I have one GTX 560 Ti right now, and I'm considering SLI-ing it up for BF3, and I have some quick questions:
1. Will my PSU suffice? If not, I'm not going to buy another (and will just throw out the idea of SLI), I pretty much just bought this a month ago: http://www.newegg.com/Product/Product.aspx?Item=N82E16817815010
2. This is my case, things are relatively cool in it, am I going to have any increased heat concerns, you think? http://www.newegg.com/Product/Product.aspx?Item=N82E16811112238 If so, would getting two 140mm exhaust fans for the top help with that at all, or is there anything else I could do that'd be relatively inexpensive?
3. Does it matter what brand the second GTX 560 Ti is? Right now, I have a PNY one, and I know that with SLI, it clocks down the lowest card and all that, but do the brands have to match? I've heard conflicting things about this. I've seen a few MSI ones go fairly cheaply on ebay, and if I could snag one of those, I'd totally like to actually save the money.
4) Lastly, aside from power, heat, and microstuttering, are there any other drawbacks of SLI I should be aware of?
Thank you for your help and time!
