Hi
I am new to water cooling stuff and i am planning on building a new pc, my friend has a water cooling and i asked him for advice so he told me that i should get a 120.4 for the GPU and 120.3 or 120.2 for CPU.
and for the case he told me about caselabs, so i was sondering if a regular full tower will be ok with me and i will get alot of space, the space is what i worry about that is why he suggested the caselabs.
and btw i dont want to buy the kits, i want to build it custom so what i am wondering here is that do i really need 2 radiators for my loop?
here are the specs i will be buying for my new PC:
VGA: EVGA GTX 980 (for now i will get 1 only but later i will be doing SLI so total of 2 VGA)
CPU: Intel i7 5930K
Planning on overclocking both
I will water cool the VGA and CPU so i was wondering if i need 2 radiators or just 1 120.4 will be enough for gpu+cpu water cooling regarding if its 2 GPUs in SLI or 1 GPU only.
And also he suggested to install 2 pumps because i will be installing 2 radiators.
I want to know good custom components like radiators, pumps, water blocks that you recommend, i read a lot but most of the topics are old so that is why i asked you guys.
Thanks alot.
so what are your suggestions please.
Thanks.
CPU: Intel i7 5930K
Thanks alot.
Thanks.
