Some ODD & USB questions
Couple of questions for those in the "know"
- would a 16x DVD-ROM/24x DVD-RW saturate a dedicated USB 2.0 line (direct to computer; no hub involved)?
- anyone face issues with active USB extender cables & ODD rip/burn accuracy?
Essentially, I am looking to remotely mount an internal SATAII ODD outside of a computer 15-20 feet away. Looking at this route as all off the shelf USB external ODDs which I have found have a max ROM rate of 8x, while an internal is 16x, so copying data is noticeably slower.
So, I plan to put an internal ODD in either a USB 2.0 or 3.0 enclosure, run an active extension cable, and call it good.
Anyone ever do this? Good/bad/odd results? I could just by a USB 2.0 extender and try it out, but if it doesn't have enough bandwidth & I need to go to USB 3.0, I then reinvest in everything all over, and end up with gear I won't use otherwise.
Thanks in advance :)
It would be close, but not quite capable of carrying the peak bandwidth.
DVD-ROM write speed for that drive is 1.32MB/s * 24x = 31.6MB/s
USB2 is usually only good for 20-25MB/s write speeds:
http://www.tomshardware.com/charts/usb-3.0-storage-charts/Copy-Benchmark-Images-Write,2282.html
You should probably go USB 3.0, but consider the following:
http://en.wikipedia.org/wiki/DVD-R#Speed
The difference in write time between 16x and 24x is less than 2 minutes. You might not care about maxing out the drive if a couple minutes do not matter to you. It will still be faster than the 8x max speed you can get on the typical notebook drive attached via USB 2.0.
Thanks for the info. I will just do 3.0 and be done with it.
Active repeater extensions are a little pricey, but I prefer to "do it once & do it right"
