WCES Ryan said:Just a few questions about the swiftech MCP655 pump....
1) Can it be mounted on its side?
2) Is it possible (and how easy) to put a 90 degree fitting on the top?
3) Does the unit create a lot of heat? How about vibration?
willie92 said:Somewhere in this watercooling forum I remember reading a guy had found some 90 degree angled fittings but they made the turn rather gradually rather than the sharp stuff that typically see. I thought I'd bookmarked it, but I guess I didn't... Sorry!![]()
malicious said:running through the holes i like .. mounting on it's side i don't
did you get a manual .. check it .. if not let me know
mal
edit: I have a MCP650/D4 for sale in the FS: forum if anybody is interested .. bump if you go there plz
cheers
