Some Lights and other bits...
SidewinderX
Hey guys,
I was planning on buying a few things, and I figured I'd run them by ya'll to see if anyhting jumps out at ya'll or anyhting...
First off: The rig as is:
http://s89737224.onlinehome.us/photo/PC/case.jpg
http://s89737224.onlinehome.us/photo/PC/case1.jpg
http://s89737224.onlinehome.us/photo/PC/opencase.jpg
It currently has a vantec stealth 92mm fan in the front, an 80mm in the side, and 2 80mm uv reactive fans in the back.
What I'm planning to do:
I can get a decent dremel for pretty cheap, so me and a friend are gonna split it. I'm planning on using it to cut the ducts that the case has on the back off (seen here: http://s89737224.onlinehome.us/photo/PC/backcase.jpg ), as well has cutting out a hole in the top of the case for another 80mm fan.
And then I was planning on buying this stuff for looks and to clean up inside a bit.
http://www.xoxide.com/uvsegr18rofl.html : green UV reactive round FDD cable
http://www.xoxide.com/gruvse24roid.html: 2x green UV reactice round IDE cable (24")
http://www.xoxide.com/1grwilo.html: 7' green wire loom (for good measure)
EDIT I'm stupid, fogot this
http://www.xoxide.com/colcatblac.html : UV cold cathode (and secondary bulb)
and another green UV reactive 80mm fan (for the top)
Anything horrible wrong with that?
STOP! please dont waste your money on that site. they do have some neat things but are sooooo expensive. for the cathods and cables go here . not only is it cheaper, xoxides cathods are not very good
thanks for the advice, but the only things that are cheaper are the cathodes and floppy cables. They don't have the tubing I want either. I'll check the shipping, but it'll probably end up being faster to buy everyhting from xoxide.
well, ended up ordering the stuff. Although i did get the thermaltake ide/floppy cables cause the looked nicer, and some ramsinks for my vidcard.
What cinched it for me was thier rewards thing... 25$ giftcard after buying some stuff isn't a bad idea :)
hahah, xoxide isnt too bad for these products... i ve bought blue led fans from them for like 2 bucks and grills for 99cents... however, the xoxide brand products, dont expect performance from them... i had a neon light from them and installed it and it broke after two days... i have another neon light thats still new, (i ll install that) along with one of their dual tubes cathode light.... i only bought it cus it was cheap and was on xhour sale
