Some help with FSB/CPU dividers
V3|!UM
My setup is as follows:
Abit nf7-S
AMD barton 2500 (running at 10/200 1.65vcore)
1gig corsair twinX 3200 llpt 2-2-2-7
My main question is the fsb/cpu divider. What should it be set to?
i currently have it on auto. I want to fine tune it though and raise my mulitplier higher then 10. I tried upping the voltage to 1.85 but still hitting a roadblock. i got thermaltake silentboost with cermaique cooling the cpu.
cany anyoe give me some insight on what kind of divider i should use?
just make sure the AGP speed is set to 66mhz in bios and then up your fsb more. maybe up the ram voltage as well. is that ram rated at 2-2-2? if so raise the ram voltage all the way and then raise the fsb until you reach the chip's limit.
