Hi all! Recently decided to start building my own computer and decided to go with pcpartpicker's recommendation for a cheap but decent PC. Been having some problems and have been pulling my hair out so hopefully you can help Anyways, here are the parts:
AMD FX-8320, COOLER MASTER Hyper TX3 cooler
Biostar A960D+ (mATX)
Crucial Ballistix Sport 2x8GB
Cooler Master 620W PSU
Powercolor HD7770 Video Card
1GB Seagate HDD, 7200 RPM
Rosewill mini ATX case (92nm inflow fan in front, 80mm outflow fan in back)
So here is my problem. After playing a game like Battlefield 3, or Skyrim, for a few minutes, I notice the game starts stuttering for a few seconds, then goes back to being smooth. Then every 20 seconds or so, it will stutter for 10 seconds, then go back to smooth for 20 seconds, keep repeating.
I investigated using Prime 95, and having CPU-ID and HWMonitor open while I ran Prime 95 stress test. HWMonitor shows these in the temperatures section:
THRM
TMPIN0
TMPIN1
TMPIN2
In a separate section is
AMD Package temperature
Radeon HD7700 series temperature
Anyways. Now lets get to the stress testing. First, here are the temperatures on idle, about five minutes after booting into Windows and not doing anything, with room temperature about 75F (~24C):
THRM ~ 16-18C
TMPIN0 ~ 17-18C
TMPIN1 ~ 42-45C
TMPIN2 ~ 31C
Package temperature ~ 16-18C
HD7700 temperature ~ 34-36C
Now I open Prime 95 and start the program, here are the temperatures
THRM ~ 26-40C
TMPIN0 ~ 26-40C
TMPIN1 ~ 60-65C
TMPIN2 ~ 31C
Package temperature ~ 26-40C
Here is what happens. I didn't overclock, and CPU-ID is showing a processor frequency of 3500MHZ which is standard for my CPU.
When I run Prime95, the THRM/TMPIN0/Package all climb relatively quickly to 40C, but TMPIN1 temperature gets to 60C, then slowly climbs to 65C. The second TMPIN1 hits 65C, CPU-ID shows that my processor frequency drops to 1400MHZ. When this happens, THRM/TMPIN0/Package quickly drop to 26C, while TMPIN1 slowly goes down to 60C. The second it hits 60C, CPU-ID shows my processor frequency going back up to 3500MHZ, while THRM/TMPIN0/Package quickly hop back to 40C, and TMPIN1 goes slowly up to 65C.
The frequency at which this "throttling" occurs coincides perfectly with my experience when playing BF3/Skyrim.
So here is what I think is going on. TMPIN1 is my actual CPU temperature, not "package". It has some throttling system set up in BIOS which means at 65C, it will throttle down to save itself. So either my cooling system sucks, or something else is wrong. I really need a way to figure out if this is true, that TMPIN1 is my actual CPU temperature, because even though it behaves like it when the computer is working, the labels on temperature monitoring programs, and hell even BIOS itself make it look like the THRM/TMPIN0/Package are the CPU temperature.
I would appreciate any help or advice you can provide. Thank you
THRM
TMPIN0
TMPIN1
TMPIN2
THRM ~ 16-18C
TMPIN0 ~ 17-18C
TMPIN1 ~ 42-45C
TMPIN2 ~ 31C
THRM ~ 26-40C
TMPIN0 ~ 26-40C
TMPIN1 ~ 60-65C
TMPIN2 ~ 31C
