Blue Knight
- Dec 2, 2000
I work for a small software firm and one of our clients uses Citrix and is having problems running our software through it. Basically, to when running the .exe, the program hangs. If you go to the task manager, it shows two instances running. Shutting down one doesn't let the program continue opening
I know this is probably something on our end, but I don't have a Citrix server in house to conduct more tests on. The program and even same installation works fine across their network, and it works for us across Windows Terminal Services. Does anyone have troubleshooting ideas or tips on how to find out exactly what's happening? Or does anyone know where I can outsource a Citrix server, for like a couple of hours, just so we can test?
Thanks in Advance.
Thanks in Advance.
