Hey guys,
I'm trying to overclock my system, since I'm pretty sure I have some major room to get some more power (25c at idle, low 30c's load) with koolance water cooling.
I used to be able to use the OC settings in the bios (ASUS p4c800 deluxe with P4c 3.0ghz) to do 5% and 10% increases, but after bios updates that doesn't run stable anymore. I've tried maunually changing the settings to achieve a higher clock speed, but I can't seem to get anything stable.
I'm pretty sure I'm not setting the voltage correctly. Can anyone with a similar setup help me out? What voltage settings etc, should I have at different speeds? I'm just really worried about hurting something.
Thanks for any help!
