Hi all,
I've been building my own systems for a long time but I've never overclocked before. I decided I want to on my new rig but I have some basic questions. I use my computer for development, some video editing (1080 60p video, which is quite resource intensive to play, let alone edit), lots of video encoding (blu-ray rips etc..), and gaming of course (I play BF3 and Civ5 a ton).
Also, my place can get hot in the summertime. I don't have AC so sometimes its in the 80s in my house (ugh!) on on rare occasions, even hotter. But I'd say in general it is in the 70s.
Here are some key components I ordered:
Thanks a ton!
- CPU: 3770k
- Mobo: ASRock Z77 OC Formula
- Ram: Not sure, I have 16gb of DDR3 1600 ram in my current rig, but I'm not sure if I'll use that or get something new.
- Cooling: Cooler Master Hyper 212 (air)
- I plan to use the settings in the ASRock for auto overclocking to start. As far as I understand it, the board will adjust the multiplier and voltages automatically for me. Do you guys agree with this approach or should I attempt to set these things manually? From what I've read, I might be able to go to 4.5. We'll see I guess
- Assuming the overclock even boots, how do I test its stability? Should I run some software for a time (like memtest?). I've read a ton of suggestions but I'd like your insight on how to test this. If I'm about to knife someone in BF3 and my rig blue screens I'll rage
- If I overclock the CPO do I need to overclcok the ram too? or can it just stay at its default clock? Is there any reason why I should or shouldn't overclock the ram also (assuming its not required).
Thanks a ton!
