Some ASUS P5B Questions
trueimage
Just ordered my new HTPC build:
Asus P5B Atx LGA775 Conroe 965P DDR2 PCI-E16 3PCI-E1 3PCI 6 SATA2 Sound Raid Motherboard
Intel Core 2 Duo E6400 Dual Core Processor LGA775 Conroe 2.13GHZ 1066FSB 2MB Cache Retail Box
Nmedia HTPC-400BA Media Centre Desktop Case ATX Black 1X5.25 3X3.5INT LCD IR Rack 400W
Corsair XMS2 TWIN2X2048-6400C4PRO 2GB 2X1GB PC2-6400 DDR2-800 DDR2 Cl 4-4-4-12 240PIN Dual Memory
Evga E-GEFORCE 7900 Gs Ko 500MHZ 256MB 256BIT 1.38GHZ GDDR3 Dual DVI-I Hdtv Out Hdcp Video Card
I already have HDD / DVD.
Questions:
1. Can I boot/flash firmware from USB key? I was thinking I'd flash before even installing windows.
2. Will the 400W PSU be underpowered at stock? Overclocking? (I've heard it is a Seasonic, so at least it is a decent 400W not generic)
3. Does this board need any cooling items replaced out of the box? (NB/SB heatsinks etc) What is recommended?
4. How is the RAM I chose? That is the main component I wasn't sure of.
5. Is ASUS pronounced EH-SEUSS (like Dr. Seuss) or EH-SUS (like in sustain)?
Thanks
1. Yes, you can flash from a USB drive before installing windows. This drive has the bios flash built into bios.
2. 400W should be fine with those components as long as its a competent brand. ie, no Deer PSU.
3. No modifications should be necessary.
4. RAM selection is fine.
5. Not sure on the pronunciation.
