bigbadgreen
- Oct 2, 2003
Mods, before you move this to work log please understand that this is a post for my initial research into a mod, I'm looking for help before starting the mod. I'll make a new post when I do start.
So I came up with this idea for a case mod for my P180. A little background. For atleast the past 10 years I have been drawn to geometric shapes, and in particular circlular shapes, connected. Some people have called them crop circle like or alien like, so I have finally decided to go with a mod in an alien type of mod. Here is the idea. Don't worry no windows to show intrernals, but there is a window-esque cutout. The case will be painted gloss white where the brushed aluminum is. I'm still debating if I should paint the top. The goal is to leave the trim and front bezel black. The top is already black and I'm leaning towards painting it white. The next step is to do the cutouts, refer to the pictures, and back the hole with white plexi, that light can show through, but that appears white when no light it on, translucent i think it the technical term. Don't worry about the one shape having a piece hanging, I'll glue it to the plexi to hold it in place. In thids case I plan on using blue lighting.
Now onto my research. I need help with wiring the power switch. I want to add a panel on the top that is a touch sensitive switch. I plan on doing a trace of an alien-esque hand with metal discs flush mounted into the top of the case where the finger tips would be. It would work like a touch lamp does. In fact that is my question. Is it possible to convert the switch in a touch lamp to work in this way. other touch switches I've researched seem to cost a whole lot, in the $150+ range.
This switch plate would be covered by a clear plexi plate that is elevated, enough so that you could slide your hand in there easily, but so that it blocks accidental touches.
So any help on the switch front would be greatly appreciated.
Photoshopped pics of the idea, without work to the top, no switch done and not white.
light off
light on
light off
light on
