Why do think the 256-bit bus won't limit performance?The amount of memory is still 512MB and since this is just a new flavor or the G92 chip, it sports a 256-bit bus, which in no way will limit performance.
That's the idea...the new high-end part is the GX2, and all the new 9 series cards are just G92 or derivatives as far as I know. Who knows when the true next-gen will be out that can play crysis![]()
I find this hard to believe... NVIDIA hasn't released a new GPU for over a year. Now their new series is nothing but a die shrunk 8800 GTX? That's unbelievable. I'm guessing that this Expreview site may just be wrong. Hopefully anyway.Yeah.. but..meh.. it's stupid. Why release some a G92 part as an 8800 if you're gonna release the same damn thing 2 months later as a 9800.
Bleh.
Uh...
So they are renaming the 8800 GTS 512 to 9800 GTX?
Good job, Nvidia. :/
I'm not sure about that... I mean, look at the 9600GT vs. 8800GT. The 9600GT has roughly half the SPs, which should (all else being equal) mean roughly half the performance, but it isn't. So what has changed? If the rest of the 9xxx series follows suit, it could still be a large step up in performance (doubtful, I know, but its always fun to speculate)
Both cards are bandwith + ROP limited. Basically this is reason why 112SP vs. 64SP doesn't make that much difference (why between 8800 GTS 512 and 8800 GT main performance difference comes from clock frequencies, not SP amounts). This 64SP is basically the most optimal amount of SP's for this card.. if you go up..there's not much performance difference, but if you go down from this your performance will tank.Why is everyone thinking that this 9800GTX will not scream? Look at the 9600GT. The specs don't look good on paper but the thing is a monster for the price. The 9800GTX is basically more than twice the power of the 9600GT. It should rock, especially at a price of $400 or less.
I'll be getting one of these or a 9800GX2, but I'm not a huge fan of SLI, so I'll probably go with the GTX.
Why exactly it would be stupid?It would be spectaculary stupid for nvidia to release a 9800GTX that wasn't much faster than the 8800GTX. If we're looking at double the performance of the 9600GT then I would say that's acceptable.
There's major difference in texture filtering performance which is the main thing that causes 8800 GT to win 9600 GT. This advantage is little bit limited because 9600 GT has more effective mem bandwith even when both have same max transfer rate
And why this is stupid move for Nvidia? They are just trying to make as much money as possible like any other commercial company. Usually it happens by creating better and better cards, but when there's no real competition this happens; they don't have to improve much..their main goal is trying to make manufacturing of the card as cheap as possible, but still keep prices where they were.because in pretty much every new generation of Geforce cards, the ones with GTX/Ultra designation have been almost twice as fast as the previous generation's best.
If the rumoured specs are true it would have been far more appropriate to call it an 8900.
Unfortunately G92-GPU only has 16 ROP units.Well we can hope they might have added more Rops in 9800 too.
Anyway even if we cry about lack of innovations it's still best GPU times ever since 9500/9700 series. I mean high performance cards are available for amazingly low prices.
Do we really need to return to times of $500 monsters giving good performance and low end giving crap performance?
I don't think it would be stupid at all. Look at the 9600GT. They released a card that falls right smack dab in the middle of their 8000 series in terms of performance, but instead of calling it "8700GT" or whatever, they called it 9600GT. Look how much hype and excitement it got! You honestly think you would see this much hype if they called it 8700GT instead?
Nvidia knows they will sell more cards as "9800GTX" than say "8900GTS", so it doesn't surprise me at all that this is the name they chose.
Yuppers.. If the 8800GT and 8800GTS were Launched as 9800GT and 9800GTS, everything would be far less confusing.. I mean.. Hey.. the 9800GT performs almost as fast as the 8800GTX!
It would have been a marketing boon!
Not dieshrinks since 9800-series use the same GPU as 8800GT/8800GTS 512 (G92-A2)ie: that the 9800xx was just basically die shrinks of the 8800GT / revised 8800GTS.
http://www.vr-zone.com/articles/GeForce_9800_GTX_Card_Photos_&_Specs_Unveiled/5599.html
i believe the longer 12 layer PCB, but i don't believe the mooted specs of 23MHz on the clock and ~150MHz on the memory.
There is simply no need to got to the expense of creating another board design, especially one that is bigger and more costly, if only to boost the clocks by such a paltry amount. After all, there is a 1GB G92 GTS with memory at 2050MHz and core at ~700MHz.
If that picture truly is of the new G92 GTX then I at least am sure that the clocks will be significantly faster than the default GTS, and it will probably come with a 1GB option from day one.
http://www.google.com/search?q=8800...s=org.mozilla:en-US:official&client=firefox-aWhich GTS is that? (I havent seen it, would be interested in it)
