[solved] C# WebClient object and catching exceptions with asynchronous methods
TheDude05
I'm using the C# WebClient object and if I run the method 'DownloadFileAsync' and the remote file does not exist (AKA, I get an http 404 from the server) a WebException is not thrown. However, all of the synchronous calls do raise the exception.
The only way I can tell if the server return a 404 is by checking the length of the file I'm downloading to. If its length is zero then the remote file didn't exist. Is there a better way to catch when this condition happens? Checking the length of the downloaded file just seems hackish to me.
Finally figured it out.
The asynchronous methods don't throw the exception but pass them along with the EventArgs object to the DownloadComplete event. (Someone correct me if I'm still wrong on that)
