Flogger23m
- Jun 19, 2009
My video card is running pretty hot. Getting up to 88 degrees C when playing a game like STALKER CS or Crysis. A bit too hot for me. I am running the fan at 86%. I can turn it up to 100%, but I have a feeling running it that high will wear it out. Either way, it is running a bit too hot.
My case is an Antec Sonata 3. It is small, and not much room. My video card is too long, so I can not install the extra 120mm case fan.
I installed an Evercool Fox 1 case fan in the back slots of the case, but that never brought my video card temps down.
Aside from that, there are no places to mount my spare Antec 120mm and 80mm fans.
Will get some better pics, but this is what my case looks like:
http://img819.imageshack.us/img819/6192/dsc00770e.jpg
As you can see, not a lot of room to work with.
I was thinking, can I just some how mount my spare 120mm fan on the bottom of the case? Will that actually create good air flow to keep the heat down? And if I can, how can I mount it? Duct tape?
Can also throw one on the case door.
I've tried cleaning my video card out with compressed air, which helped a little. Still running at 86 degrees C on a hot day. Will try to clean it again, but still, I think these temps are bit high.
