solution for multipliers > 12.5 with mobiles...
rogue_jedi
this works on my a7n8x deluxe... i'm running my mobile 2400+ @ a 14x multiplier right now. it should work on any other board with 4-bit multipliers as well.
the mod is fairly simple and is based off of the pin mod at ocinside.de. just connect the indicated pins in the same way that you would use the pinmod guide. then you're done and have full control over the higher set of multipliers.
image:
disclaimer: i take no responsibility for whatever you do with this modification. if you break your hardware, then it is not my fault and you must take full responsibility for doing so. that said, this should not break anything unless you do it wrong.
p.s. lmk if you need a better image amd i'll try to get one ASAP.
