Soltek Soltek EQ-3705 or Shuttle Shuttle SN41G2V2?
nerdonsite
hi, im new to these forums and i have decided to build myself a SFF system. im looking at the athlon xp/sempron platforms since these cpus are relatively cheap. i have narrowed my choices down to the Shutle SN41g2v2 and Soltek EQ-3705. both are nf2 MCP-T and IGP (i want to use onboard graphics for now and need the tv out for temporairly watching movies on my aging tv untill i get a new dlp tv in the summer).
what i would like to know is, what are the pros and cons of each system and which one is quiter? which one is more reliable and more stable? if it were u buying one of these, which one would u buy and why?
thanks for looking.
i would like to know where if they are being made to get socket 939 boards from.. just the boards.. but i guess i could stick with a less powerful system.. for the time being..that being said.. where could one get these boards??thanks for any help..
I've stated several times in several threads, you cannot purchase the boards seperatly. Thats one of the biggest drawbacks to SFF. You gain some, you loose some.
Small Form Factor systems lose their novelty quickly, I couldn't stand being confined to using just one system.
also, in particular, I haven't had good luck with my SN41G2B
got my sn41 gv3 its suprisingly good with the correct components
right now, its just a realy low hum with smart fan enabled and the heatsink aint even warm
amd 2600+
512mb
256mb
mx 160gb
no fdd
no dvd - getting nec 3520 soon
i can play need for speed underground with the onbaroard graphics, quite good !!
