Soltek nForce3 250GB wont post
robberbaron
I set the CAS to 2 to see if the RAM could do it, and now I get this really high pitch squealing noise and nothing I do can make the system post. Yes, it was a stupid thing to do, but I'm just wondering how I can undo the changes in the bios. Flame as needed.
You can reset the bios to default settings with a jumper on the motherboard, see the motherboard manual.
So, then, clear the CMOS with the jumper, and all will be well?
Well if the problem is that the memory is set to CAS 2, then it would solve the problem. Default setting for CAS is auto.
It's fixed, thanks! I love this system. I should have known better than to set PC4200 ram to a CAS of 2 :p
Right now I'm getting 45C with an OC of 2043 (versus the 1800 stock speed)
