Soltek K8Tpro-939/venice 3200+...need help
vector2
I recently upgraded from a Tyan S2460 with dual MP's to the soltek. I wanted to try to do this upgrade without reformatting because I really don't have the time available right now. Here is the setup:
K8tpro-939
venice 3200+
1GB corsair valueselect DDR400
maxtor 40gb ATA/100
radeon x800pro
SB Live!
promise PCI ata/133 controller with DVD-ROM and DVD-RW
another generic ata controller with two HD's
When I first installed everything, I was able to boot into windows fine, update all the hardware drivers etc. A couple of times though, I would attempt to the go into the BIOS after booting and all it would go to was a blank screen (but the monitor was still registering that it was getting a signal). I would restart a couple times and everything would be fine. I got the hairbrained idea to update the bios from 1.4 to 1.6. The BIOS flash went perfectly and I'm still able to post just fine. But, I'm unable to get windows to load. All that happens is that it goes to a blank screen (still getting monitor signal) but I never get to the windows splash screen. I can F8 right before and access the menu, but when I select any option, the computer does nothing (I can usually still ctrl-alt-del so it's not a hard lock). Interestingly enough, it does something similar when I try to boot off a floppy or CD. It will begin to load and then just sit there. No errors, no blank screen. I've reset the CMOS and this hasn't helped. Unfortunately, I have no way of reflashing the BIOS since I can't boot off anything. Tell me if I've left any pertinent information out. Thanks.
