Maybe I've been lucky?
Solid States don't particularly excite me yet, because the current implementation has been clumsy. Most are PCI/PCI-E add-in boards (for desktops) that require a SATA cable. That's fine, but even SATAII gets saturated by the bandwidth of DDR400 RAM (which is generally what is used on these boards). Why not use two SATA ports, or talk through the PCI-E interface? I'm not an engineer, so I don't claim to have the solution. Plus, SSDs are expensive as a result. Did I mention the 4GB/8GB limit? I know there are some superdense 32Gb (yes the small b was on purpose) drives and the like, but those are even more expensive (assuming you can even buy them).
However, when solid states do come into their own, laptop users will see huge benefits. How long have most laptops used 5400RPM drives to save power? Hybrid and solid state drives will make using a laptop far more enjoyable. And of course, power usage will go down.
[LYL]Homer;1030761908 said:I thought this was new too, at least as a high-end consumer item.
If they've been out a while in server or other environments are they reliable, what has been the cost/size?
What do you guys think of this?
http://www.sandisk.com/Corporate/PressRoom/PressReleases/PressRelease.aspx?ID=3732
SanDisk Launches 2.5-Inch Solid State Drive to Replace Hard Disks in Mainstream Notebook Computers
MILPITAS, CALIFORNIA, MARCH 13, 2007 SanDisk® Corporation (NASDAQ: SNDK) today broadened its solid state drive (SSD) product line for the portable computer market with the introduction of a 32-gigabyte (GB)1, 2.5-inch Serial ATA (SATA) interface model, compatible with most mainstream notebook designs. Coming just two months after SanDisk introduced a 1.8-inch SSD for ultraportable notebooks, the 2.5-inch SSD is now available to PC manufacturers as a drop-in replacement for hard disk drives.
where can i find that for sale?![]()
this thing makes me excited just like when i got my first 2x cdrom!
thanks.
I run quite a few hard drives and I haven't found there to be any failures for the past few years now... however, I do have friends who seems to be passing through hard drives as a fat kid would with bigmacs.
