mich43L said:You'll be amazed how long a twist-and-tape method will last. The problem with the solder method is that the in-dash wires sometimes aren't long enough for a comfortable/safe soldering job. I used quick-disconnect (in case I made a mistake) crimp connectors from radioshack.
I want it done right and quick, meaning crimp connections or wire nuts.agent420 said:and more importantly, do you want it done right, or do you want it done quick?
