- Jul 27, 2006
Ok, so on my two 19" LCD monitors I found busted/bursted/blown/round caps on the power supply board. I took them off, made some marks, and ordered new ones. So now I have the new ones.
Is there a positive and negative end? A wrong way to install a capacitor? Do I just simply put the capacitor through the two holes on the board where it is supposed to go, regardless if which wire goes through either hole?
The type of capacitor I am talking about are one of those small, tall cylinder capacitors.
